Panasonic SA-PT 760 - problem with digital audio cable or port!
Username: Vinny_blair
Cincinnati, Ohio US
My story is below:
1) I bought this unit early in 2009 so its out of warranty
2) I have it connected to an LED TV via a digital audio cable
3) My previous TV was connected to it via component inputs
4) I bought the new TV in February 2010 and it has been working without a hitch until this past Wednesday (July 7, 2010): I turned the TV, the satellite box, and the surround sound unit off when went to bed the night before --when I turned it on the next morning there was no sound
5) When I reached behind the surround sound unit, I expected to find the digital audio cable had come loose: it was inded loose but still in the jack in the back of the surround sound unit
6) When I wiggled the cord, i got static out of the speakers and when I found a "sweet spot", I got the sound to come out of all the speakers (as normal) BUT there was a delay between the video and the audio (and it was on every channel).
7) I called Panasonic tech support and they told me that the unit needed to be taken in for evaluation: I did that and they said the optical port was bad and that it was the first time they had ever seen that happen in that specific unit.
8) $60.00 later, I brought the unit home yesterday and plugged it back into my existing digital audio cable (a 12' moster cable I bought from Crutchfield) and it worked fine when I first sat down to watch TV.
9) We turned the system off while eating dinner and turned it back on to watch a movie later on. Again - dead quiet - no sound and the same crackling sound if I moved the cable around inthe port.
10) On a whim, I went to Target today and bought a very cheap Sony digital audio cable and plugged that into both the TV and the surrpound sound unit. I noticed that the tips on the ends of the Sony cable were longer than that of the Monster cable and when I plugged it in, the sound was perfect. There was also no change when I tried to move the cable around in the back.
Given my story above, I was wondering if anyone else has experienced this problem. Was my $60 monster cable actually defective or is this really an issue with my surround sound unit (give that this happened both before and after repair with the existing cable)?
I still think Ive got some electronic gremlins or something but I've been scratching my head over this one -- the repair guy told me he'd never seen a Panasonic unit in for this type of problem and I've had other units and systems that used the digital audio port and never had a problem.
Thanks so much for your replies!!!
Username: Vm8444
TorontoCanada
Post Number: 250
could of been faulty cable that happens.but....
Vinny I hate to burst your bubble but why are you hooking it up with a digital audio cable?
why you are using is the tv optical difital out from tv?
what sources do you have?
dvd,
cable box etc
do they have hdmi?
cause I know the panasonic does.
basically all cables go into reciever then one hdmi out to tv.
then turn volume down on tv.
theaudioguy.ca
Need to Register?
Forgot Password?
Enable HTML code in message
