Hooking up home theatre to tv
Username: Lilotc63
can anyone tell me how to hook up a home theatre to a tv that only has audio input jacks?????
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 552
Not really, I mean there is a way but you don't want to go there!
OK now I will actually try to be helpful - What sounds are you trying to hear through the home theater? (Examples would be a cable/Satellite box, DVD player, VCR, etc.)
Depending on the Home Theater package you generally hook all of the devices up to it befor running a signal to the TV.
Username: Lilotc63
Ha! The TV sound won't come through the home theatre...the dvd sound does just not the TV
Username: Jrbay
Post Number: 553
Do you have cable or Satellite service?
Username: Lilotc63
cable - no converter boxes though
Username: Jrbay
Post Number: 554
That is the problem then, how about a VCR? You could connect your cable to a VCR and take the audio out of it to the Home Theater and the video off to the TV
Username: Lilotc63
Screw it! I think I'll just get another TV - do I just have to make sure the TV I get has an audio output? I have surround sound systems hooked up to every tv in our house and I've hooked them up myself and have never had a problem. thanks
Username: Jrbay
Post Number: 555
The other option is to get a converter box.
Username: Vinhtayler
I recently bought a Phillips home theater. It came with speakers and dvd player.I have hooked up everything to my flat screen TV, and the sound works when I watch dvds. How do I hook it up so that I can hear regular tv through the surround sound speakers too?
home theater discount
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 733
The TV does not get hooked up to the surround system the CABLE BOX does.
Username: Valeriayiskah
It's a digital connection and not subject to loss like an analog connection. Depending on the age of your equipment, you may not have hdmi. If not, use component.Connect all the components to it and then one output to the TV input . This will make it so when you turn the receiver to an input, the video will automatically go to the tv. wilson amplifiers | wilson signal booster
Username: Satbheem
i have great confusion on selecting the home theater speakers
which one is best
BOSE or WHARFODALE or MONITOR AUDIO
MY room size is 12*20 feet , amp rms 75 denon
Username: Vm8444
TorontoCanada
Post Number: 199
of those 3
monitor audio
Username: Satbheem
my budget is for $700 or 35k rupee..
so which one is the best to my budget, with decent quality.and performance
Username: Satbheem
i planned to go for wharfedale than monitor audio based on the comments from the net.
any one willing to give a better aggressive review give it soon plzzzzz.
Username: Vm8444
TorontoCanada
Post Number: 202
I owned wharfedale before they are good.
which model?
review:
http://www.stereophile.com/budgetcomponents/1105wharfedale/
theaudioguy.ca
Username: Satbheem
Post Number: 7
wharfedale diamond 10.1 sub , and speakers i am going to choose
monitor audio.. or wharfedale 9.1
Username: Vm8444
TorontoCanada
Post Number: 204
listen then choose!
Need to Register?
Forgot Password?
Enable HTML code in message
