Compatible BOSE subwoofer for AV38 media center & jewel cube speakers
Username: Avy
Hi there,
I am a new member on forum. thank you in advance for helping me out.
I have following:
1. Bose AV38 Media center
2. Bose jewel cube speaker
Please advise which bose subwoofer should I aim to look for. Can I use any of bose PS28, 38 or 48. If yes, how much is the difference between the sound ouput of PS28 and PS48.
Username: Melnoodelman
Toronto, Ontario Canada
You should be able to use any Bose PS28, PS38, PS48 subwoofer. They are all pretty much compatible. When looking, make sure you can get the right cable to connect the media center to the subwoofer. A lot are sold without the cable.
Note: I have a Bose PS38 Series 1 subwoofer for sale if you are interested. Just had it checked out at the local Bose store and hooked it up to the current v48 system and worked fine.
Need to Register?
Forgot Password?
Enable HTML code in message
