*Help* Recommendation of wireless HT systems!
Username: Aydene
Hi guys! Im really new here. dont know if i even posted at the wrong section =\ My dad asked me to look for wireless HT systems though i kindda feel that wireless never sounds half as good compared to wired ones. So can one just recommend me some really good ones? Dont really have a budget, just as high as it can get. Thanks peeps!
Username: Rmammerschuber
NY USA
Post Number: 114
If you go wireless and you also have wifi you will have problems with both. Stick with wired...
Username: Aydene
But is there any good ones to be recommended? So i'll just have the info. Thanks!
Username: Plymouth
Post Number: 16432
Welcome to eCoustics AydenEd!
Acoustics reserch do well!
http://www.audioholics.com/reviews/speakers/satellite/acoustic-research-wht6024- wireless
http://reviews.cnet.com/surround-speaker-systems/acoustic-research-wht6024/4505- 7868_7-32638450.html
Need to Register?
Forgot Password?
Enable HTML code in message
