Surround sound doesn't work with sat. Only with dvd
Username: Mlhkmh
We just bought a Toshiba 55ht1u. The surround sound works with
The DVD and wii but not the direct tv. Any idea what to do?
Username: Superjazzyjames
Post Number: 552
Is your satellite box HD? If not, you may need to upgrade. Make sure the channel you're watching is HD. What type of connection are you using? Digital coax, digital, optic or HDMI should work. You may have to go into menus and switch things in your sat box, TV or both. If none of this works, call direct TV. They might be able to help you via phone or send a tech out. They shouldn't charge for it.
Username: Plymouth
Post Number: 15635
Mlhkmh
Are you using the optical output?
Need to Register?
Forgot Password?
Enable HTML code in message
