Component Video Card
Username: Mrckone
Toledo, Ohio U.S.A.
Post Number: 7
I am a little new to the HTPC scene and was just wondering if there was a video card that has component out put on it with out using an adaptor?
I currently have an NVIDIA GeForce FX5500 that I am having difficulty with the adaptor to go from DVI to component.
So far all the answers have not helped, but thank you anyways. Also, I know that there is a company called Audio Authority that makes a transcoder that has a VGA in and Component out.
Thanks in advance for any help
Need to Register?
Forgot Password?
Enable HTML code in message
