RCA RT2390
Jeremy Ventkins
Looks like RCA updated their RT2380BK model by adding another 100 watts of power. What I'm most interested in, however, is whether -- or not -- they fixed the problems with the receiver. If you remember, a couple of you observed that the sound would cut out for a few seconds about an hour or so into a DVD (see the other RT2380 threads for more details). Possibly a buffer problem. Is that still the case?
Radu
I was thinking of buying one to replace my 2380 and try out the new subwoofer, as well. I will report back by the weekend if I bought it.
