HELP! Odd room shape, so need ADVICE!
Username: Jonandabby
have a very odd shaped room, and want to put in surround sound. Here are the limitations of the room:
1) I cannot put the speakers behind me (sofa against wall);
2) I cannot put the speakers on the side walls (one side is a window, the other is a passthrough to a kitchen.
I really need something that can be mounted on the back wall, and then adjusted to point sideways. I had been considering the Bose AM 15 or 10 systems. But I don't much care for Bose.
Are there any other quality systems with really small speakers that can be adjusted to fit the shape of my room like Bose's? I don't want to spend silly money, but anything under $1000 before installation would be something I'd consider. The priorities are small and adjustable (and good), not cheap.
PS I have an Onkyo TX-SR601.
Username: Nossus
CT
Post Number: 9
Check out this discussion for reviews and opinions of Orb Audio, https://www.ecoustics.com/electronics/forum/home-theater/9497.html and their website at www.orbaudio.com. The speakers are small and attractive. The system is affordable and, according to all, the sound surpasses Bose.
I have a surround set up of Mod2's wall mounted - except the center speaker - and am pleased, as is my wife, with the setup. I found some adjustable wall mounts for $12.00 each on the net which work perfectly mounted to the side walls - pointing sideways - and can even be mounted on the ceiling. I bought them here http://www.sjgreatdeals.com/tb-satsw.html
