Setting up a new 7.1 systme
Username: Chitown
Ladies and Gent, I am setting up a whole new stereo system based on a Marantz SR8400 that I just got. My question is can I recycle my Boston Accoustic Speaker (2+subwoofer about 13 years old not sure of the model) in conjuction with another set of 4 or 5 speakers or should I buy a whole differnt set of one brand? If I can use them where would I place them? Any suggestions for a 5.1 or 7.1 set under $800?
Username: Swwdts
I bought a 6.1 matrixed Kenwood system for $500 at BestBuy.I don't use the main speakers that came w/ it only the 8" 100watt powered subwoofer.The speakers I use are Sony.If you want to keep your set-up, go to the thx website & take the link that leads you to room/speaker set-up.
