Receiver keeps turning off! Please help.
Username: Schalicto
I have a kenwood VR307 which you guys recently helped me set up for dolby digital, but now when I use dolby digital the reciver shuts itself off! I can use sterio, pro logic, and even virtual surround just fine, but when I use prologic or dts it shuts itself off. Then I have to accually press the off button to turn it off, then turn it back on. Any suggestions?
Thanks!
Josh Parker
TPE
Sounds like the 'protection' on the receiver is kicking in. Try a basic 'reset' on the unit
