I need help!!!
Username: Jogbin
I want to buy the Onkyo HTS 770 and I hear a whole bunch of stuff about the wires being bad. My question is which wires should I get to replace and are subwoofer and speaker wires different.
I would appreciate any help.
Username: Thalazy
San Ramon, California U.S.A
Post Number: 19
Monster Xp speaker wires are the best of the best without spending hunders of dollars, and Monsterbass sub cable is also great for replacing your sub cable. The subwoofer uses a cable so it is different than the the wire which hooks up to the speakers.
Here is alink for the speaker wire, it comes in different sizes and several different colors, http://www.circuitcity.com/ssm/Monster-Cable-Monster-XP-Compact-Speaker-Cable-XP MS100-/sem/rpsm/oid/8416/rpem/ccd/productDetail.do
as for the Sub cable, it omes in different lenghts
http://www.circuitcity.com/ssm/Monster-Cable-MonsterBass-300-Subwoofer-Cable-MB3 00SW18-/sem/rpsm/oid/26170/rpem/ccd/productDetail.do
there are many different brands, I use those two products and they really make a difference, and Monster is one of the best. Hope this helps.
