Onkyo HT-S760 Home Theater
Username: Silas92
Post Number: 11
Is the Onkyo HT-S760 Home Theater better than the yamaha yht-360?
Username: Project6
Post Number: 7374
Some think so and some do not. It really depends on you and what you think is better. Go out there, listen and make a determination.
Username: Mmastin
Colorado Springs, CO USA
Sorry for the late post, but I am not on this forum often. I have the Onkyo HT-s780. It rocks. I think the yamaha is very much a budget time offering where as the Onkyo is price wise, but not performance wise. If they both sound good to you then check out connections and numbers to see which fits your needs.
