Feeler: Zapco, Clarion, DD/RE
Username: Frkkevin
Post Number: 3184
Pictures
Clarion 4/3/2 APA4162 - http://www.putfile.com/frkkevin/images/83415
Zapco Amps - http://www.putfile.com/frkkevin/images/84589
RE/DD - http://www.putfile.com/frkkevin/images/84771
If you want to buy the Zapcos.. I'd like to sell them as a set.. perfect for an active setup..
PRICING* Make Offers...
DD/RE Hybrid
DVC 1 ohm
If you don't know what it can do.. well pfft on you. RE SX motor.. 15" black basket with DD soft-parts.. this was a recone and whoever did it did not use correct tinsel lead lengths the tinsel slap created a tiny hole in the top of the spider.. sub plays fine but has tinsel slap.. can be fixed by re-soldering the tinsels and siliconing the tiny hole.
Equipment needed.. Let me know what you got.. really looking for some more SX 15"s or maybe some high end components (6.5")
Maximum Power Output 260w (65wx4)
Continous Average Power Output 160w (40x4 into 4ohms 20Hz-20kHz @ 0.08% THD
Typical 2-ohm Stereo 65wx4 @ 0.8% THD
Typical Bridged Power 120wx2 @ 0.8% THD
Bass Exterender Control 0-12dB
Adjustable 4-channel 50hz-200hz, 12dB/oct. High/Low Pass Crossover
Mixed-Mode Operation
Bridgable 4-, 3, or 2-Channel Operation
Pulse-Width Regulated MOSFET Power Supply
Zapco MODEL Z100S2
2 x 50w rms
Specs:
Power/Mode
130 watts @ 4 ohm Stereo .02% THD
190 watts @ 2 ohm Stereo .04% THD
190 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 40 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 30A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .8A
Dimensions 10.25"x6"x2.25"
Zapco MODEL Z150S2
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Fuse Internal, 20A
Idle Current .85A
Dimensions 11.625"x6"x2.25"
Username: Logan__tille
Imortal Box Building
Post Number: 6100
Will that imbread RE sub get me 150dB's?
Username: Frkkevin
Post Number: 3185
Throw enough power to it and I don't see why not.. all in the install man.. you can break a 150 with a single 8" if you know what your doing :-)
I'd sell it all for $400+ shipping if someone could paypal me today :-)
Username: Van_man
Boston South, MA
Post Number: 2043
Hey frank, Try listing them on Zapcos forum. They have a good FS section. Great site too.
Username: Van_man
Boston South, MA
Post Number: 2044
Sorry, "Kevin".
Username: Frkkevin
Post Number: 3245
No interested?
Username: Frkkevin
Post Number: 3260
pics of the Zapcos on ... did not have time to dig out the clarion from storage
http://www.putfile.com/frkkevin/images/86999
Username: •cam•
Post Number: 105
are the zapcos underrated?
Username: Frkkevin
Post Number: 3263
yes
Username: Frkkevin
Post Number: 3294
i guess no one trusts me!? Lol
Username: Frkkevin
Post Number: 3317
so peeps will get off my nutz.. just did some testing on the SX.. its going to need a recone so be aware..
Username: Frkkevin
Post Number: 3327
ZAPCOS SOLD
New price for the Clarion.. $65 shipped
