Can't transfer photos from iphone to pc
Username: Wentworth_miller
意大利
There are some photos in my iphone and I have to transfer them to my pc for editing. So I synced my iphone to computer and open itunes. Normally the pictures will appear on itunes but this time the folder was empty! I really don't know what's going wrong! Could u pls help me...
Username: Rjs9163
Post Number: 11
I don't have much idea about itunes but you can try to put those pictures on to your pc with the software called as Picasa or attach your iphone with a USB to the pc and copy all your images onto it.
Username: Sofiasara
Post Number: 16
If you are trying to transfer your document from your I-phone to your PC here are some simple steps you have to follow.
1.Plugin your iPhone to the computer without iTunes running
2.Wait for a popup asking you what you want to do with the device
3.Select View Content
4.Find your photos through the folders that are displayed
5.Copy in Windows as usual.
Follow these above steps and enjoy.
Username: Rogerafrance
you just connect your iPhone to PC and wait for the Auto-Play pop up. There are some software available in the online market to transfer iPhone content including iPhone photos to computer without iTunes.
Username: Polterman55
Very important advices, also helped mi with my problems. Thanks a lot
Username: Cavinya
What cool applications do you know for iPhone, or MacBook, I really liked their ecosystem and how the devices are connected with each other, but it seems to me that it can be done even cooler, what applications would you recommend for this?
Username: Riverbill
You need to download iTunes then connect your iPhone with pc in order to transfer the data from iPhone to pc.
Username: Richardrichierich
California, California USA
What format do you have your photos saved in?
Need to Register?
Forgot Password?
Enable HTML code in message
