Speaker systems live sound
Username: Risenchikore
i have an Ev elx system 400 watts rms 1600 Watts peak. i blew subs but didnt hear them struggling
what size amp will be best for me
Diamond Member
Www.stainles... .ecrater.com
Post Number: 25650
Well you have 400w RMS speakers, why would you run any higher power to them then that? Peak power ratings are a dangerous number in that it gives the consumer a false sense of capability. Peak power ratings are for the short bursts in music and should never be considered the constant power delivered to them. Send clean 400w to them as their rating states.
What size amp did you power them with that blew them?
Username: Angeljoe
Agree with Paul Larrea. You need higher power.
Need to Register?
Forgot Password?
Enable HTML code in message
