How do electronic blow out candles work?
Username: Candypants
Post Number: 9
Ok, this might be a peculiar question, but I was having a discussion with a friend about those blow on/blow off candles and how they work. We both have our own theories and of course I think I have the most logical one, so I thought I'd ask you guys what your opinion is. What do you think the mechanism is behind the electronic candles to get them blown out?
Diamond Member
Www.stainles... .ecrater.com
Post Number: 24254
Wasn't hard to find out where you C/P that from.
http://http://www.dcemu.co.uk/vbulletin/showthread.php?t=351387
Username: Wolf_hound
Phoenix, AZ
Post Number: 1322
http://forums.pcworld.com/index.php?/topic/106932-how-do-electronic-blow-out-can dles-work/
Diamond Member
Post Number: 24267
OP is probably a bot of some kind.
Username: Dollface5566
Post Number: 21
Sound sensor? I have a set from Philips which you have to turn upside down in order to turn them on or off. Which means there's a motion sensor in them probably.
