BitTorrent Problems
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 2908
I just got DSL at the house today (NO MORE DIAL UP!) and I downloaded bittorrent and its downloading things as slow or slower than dial up did... Is there something I need to change? I cant figure it out but I am by no means a computer genius. Thanks guys
Username: Mrskullz1
Brooklyn, New York
Post Number: 895
Andrew, you should try to check out your settings/filters in the options.
Also check out if firewall is enabled...that may be an issue.
You don't really need to be a genius to change some settings. It should mainly be your filters.
ORRRR your prob downloading a torrent that has very few to none seeders.
BTW what bittorrent program are you using?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8776
Your DSL modem probably also acts as a router and has a hardware firewall built in. You need to open ports 6881-6889.
Andrew Capps, NC US
Post Number: 2909
I've already messed with the filters and firewalls
Ill open the ports when I get home. The internet is quick but just the torrent manager.
BTW, Im using BitTorrent as the program
Username: Mrskullz1
Brooklyn, New York
Post Number: 896
i used to use uTorrent before to download all my torrents and i always used to get sh!tty speeds. I tried Bitlord and got much better speeds.
Don't know if its the program or what but it did make a biggg difference for me in the speeds i got.
Just my .02
Username: The_image_dynamic
San Diego, California
Post Number: 4675
I prefer µtorrent but BitLord is also good and BitComet too. Anyways, it has way more to do with what your settings are than what client you use. Get µtorrent here: http://download.utorrent.com/1.8.1/utorrent.exe and/or BitLord here: http://www.bitlord.com/BitLord_1.01.exe, find a cd you want using this: http://torrent-finder.com/ that has alot of seeders (80+) and go. If it is still slow we will have to go through your settings.
Andrew Capps, NC US
Post Number: 2910
Im still only downloading at 40kbps on 1.5mbps DSL. I cant figure out how to change my ports...
Post Number: 4676
First of all make sure your XP firewall is off like it should be. Then use this:
http://forums.afterdawn.com/thread_view.cfm/87547
Username: Livin_loud
COD4 Addict
Post Number: 2700
do you have comcast?
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1492
comcast dosen't offer dsl.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2426
The problem is....you're using torrents lol.
