Samsung Phone Manager
Username: Livin_loud
Post Number: 2569
just picked up a samsung glyde and need a program to manage things. i had an LG phone and used "bitpim" to put ringtones on it and such, and it worked wonderfully. so i need something similar to do that to this phone now. tried searching around a bit but haven't found anything worthwhile yet. anybody know of any good ones?
Username: The_image_dynamic
San Diego, California
Post Number: 4486
http://www.mobtime.com/en/cpm/cpm_en_v6.1.0.exe
http://www.sendspace.com/file/psrkhj
Post Number: 4487
That last one has most samsung phones but I dunnno about that one because it is new. Try this one if the other fails.
http://rapidshare.com/files/75203475/Mobile.Master.Corporate.Edition.v7.0-YAG.ra r
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1445
if u have verizon just use a audio editor and send the mp3 ringtone to ur phone at Yournumber@vzwpix.com just make them under 500kb or they wont send. also bit pim still should work u just need a diff version im sure if u google u can find it.
Post Number: 2579
i've seen that method floating around Keith and i'm about to try it out. neither programs work Brad, but thanks. i've recently discovered howardforums and have been browsing around there for a bit, but nothing ground breaking yet.
Post Number: 2582
success :-)
got a program called QPST. Qualcomm makes it. its a bit more direct than i'd like but it's damn powerful. got ringtones down now i just need to figure out pictures and such...
Username: Kpa2727
Post Number: 1453
