I need microsoft word 2007 FAST
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2226
Alright, so I currently have the trial version of Microsoft word and it ends
tomorrow night at midnight.(Friday, May 30)
I'm doing a project for my auto class and I need it to finish it. If anyone can find me a 25 character key code it would be greatly appreciated.
Thanks.
Username: The_image_dynamic
San Diego, California
Post Number: 4010
Q4P7J-F6829-RBQ2Q-KP64C-7HQQ8
JPYHY-TCJDC-2X8XM-J7RC3-JB6HW
B33GW-8Y2CR-7C489-P493M-VX87W
V9F39-WT6PJ-4B7HC-BC2HK-FRHD8
KKMWP-YG9JK-9R39F-3DGF3-388BJ
Post Number: 2228
DAMN!!! That was fast.
You're a lifesaver, Brad. I'll try them out right now.
Post Number: 2229
Damn. None of them worked. :-(
Post Number: 4012
Browse to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
Right click on Proof.XML file, select "Open With..." in the right click menu.
In the "Open With" window, select Notepad to be used to open the XML file. In Vista, if you can't see the Notepad option, simply double click the "Other Programs" to unhide it.
Scroll down to the bottom of the Proof.XML to locate the following lines:
/Feature> <Feature Id="SetupXmlFiles" Cost="1248&#8243;
OptionRef Id="AlwaysInstalled"/
Change the AlwaysInsalled to neverInstalled so that the line looks like following:
OptionRef Id="neverInstalled"/
Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
Username: Livin_loud
COD4 Addict -PS3-
Post Number: 2481
if you can do without word, i would suggest going to openoffice.org
Post Number: 2230
Alright, so I followed everything but when I try to save it this pops up:
Then after I click OK it takes me to the save as menu.....?
Username: Bernymac
Cambodia
Post Number: 3981
VP2QC-H7QGM-GQ64F-VCCRW-7W3Q8
Q733J-99RFW-MFV9Y-RH9WG-2TJBJ
try these
Post Number: 2231
Nope, they don't work. Thanks anyways, Berny. ;)
Post Number: 2237
bump...
Username: Snowball123
West Allis, WI United States
Post Number: 736
nucka.
Post Number: 737
i dont think this serial will work but its worth a shot.
Post Number: 2238
Alright thanks man. I'll try it out tomorrow. I'm too lazy to do it now. That one keygen isn't even 25 characters.
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1315
RF737-TGCHY-6C7QY-WWY2H-FMPVW
Username: Kpa2727
Post Number: 1316
i have a nice generator that can activate all apps in office 2007 so that should work for you.
Username: Skibum12189
Cleveland
Post Number: 2906
try buzzword.com its basically a free microsoft word, its nice
Post Number: 2241
It didnt work Keith.
A pic is worth 1000 posts!!
Post Number: 16904
Word USED to come free with windows too.
Username: Kpa2727
Post Number: 1322
steve be more specific is it acctually microsoft word 2007? or is it office 2007 word? cause when i googled i couldn't find much on word 2007. btw i think i accidently gave u word 2007 vista serial. if u can provide a link to where you got your trial i'll get you a unlock.
Post Number: 2242
Well, when I bought the computer 2 months ago it came with the trial of "microsoft office 2007." Now the trial is up, and it asks for the 25 character code to convert it to the regular version. I have vista btw.
Post Number: 2243
Post Number: 2244
Then when I go to it, it asks for this:
After I click convert it goes here where I enter the key:
Post Number: 2245
NVM now. I just found a torrent that had a working code. Thanks for everyones help though.
Username: Nicksfreakinwebsite
USA!!!
so what is the code i'm stumped
i've read all this and tried every thing you sad but i just had an idea
Post Number: 2522
I actually uninstalled word 2007 because its absolute garbage. I got word 2003 from a friend. If you have 2007 right now and your trial is up and it's asking for the 25 character key code then one of these will work:
DDY79-433JV-2RXGX-MQFQP-PFDH8
WRGJQ-2J2HB-8XP8D-6J2YK-BMFFD
HX2HC-MJM6Q-4487F-23FMP-9VKV8
HX2DJ-36TJX-CRVRJ-C72Q8-CJTBQ
V82W3-BM72R-XRHWG-CP69F-4FPMT
VHGFG-FVMY3-HHP46-RXVDJ-8R6BY
TC2QP-QBCP7-WQ62V-WBF92-WWG73
WQ27D-PY77P-R9CQK-MCPPB-QGJYQ
I think the first one worked for me.
