Torrent help - Network wiz's
Username: Livin_loud
COD4 Addict
Post Number: 2290
client: utorrent
problem: nothing is really dl'ing or ul'ing. everything went down the sh!tter...
i've just hit a wall of ceased function. i recently changed my "maxhalfopen" tcp option from like 8 to 60. now at 20... torrents may pick some speed up for a few minutes, but they die shortly after. nothing above 10kbps
disabled my firewall which yielded no results. might try forwarding my port?
Username: Nd4spd18
Northwest PA
Post Number: 6643
Open your bittorrent program. Then scan ports 6881 to 6889, thats what bittorrent uses.
Username: The_image_dynamic
San Diego
Post Number: 3523
Don't change your maxhalfopen value, or any of the advanced options for that matter. Set your incoming port selection to 11256. Also check that your Global Bandwidth Limiting is set to 0 (zero) on the download side. Are you sure the torrents you are testing on have enough seeders to go faster? While you are downloading a torrent, right click on it and click "Update Tracker" a few times. Use this for your tests to be sure:
COD4 Addict
Post Number: 2292
M.S. - no response in any of the ports lol
Brad - set maxhalfopen back to 8, changed port, saw immediate response. plenty of seeds for all. things look to be back and kickin :-)
now i can get my relax with nature cd's lol. i'll get the BC album while i'm at it too. should be a good listen. thanks!
