Vizio 42" L42HDTV10A Sound will not turn down on TV speakers.
Username: Dtropnevad05
Hi everyone, new here and hoping someone can answer my question below.
OK we have the above Vizio and all of the sudden the volume on the TV speakers is at 100% and will not go down. If we turn the TV speakers on you hear a buzz then after about 15 seconds the sound comes on @ 100% even with the volume turned all the way down. We can run the audio through the surround sound just fine, we just can use the TV speakers for the X-Box. We do not want to run the X-Box through the S/S if we do not have to. Is there an easy fix or does it sound like the main board is bad?
Any help or ideas will be greatly appreciated.
Thanks Don
Need to Register?
Forgot Password?
Enable HTML code in message
