Transferring files to external HDD/Macbook from LG RH398H
Username: Qz212
I have a LG RH387H DVD Recorder. Would like to save the movies out to my external HDD/Macbook, does this transferring lower down the quality of the movie? How can i connect them?
Would appreciate if anyone can help. Have tried to burn the movie out in DVD+R, but the quality drops from 1080i to 720*5....
Username: Ieee488
Post Number: 648
You're not going to be able to get HD.
If you want that, you'll need to build your own recorder using a DVR board in a PC.
Need to Register?
Forgot Password?
Enable HTML code in message
