Viewsat Ultra with WF Instructions May 2011
Username: Jeffw427
St. catharines, Ontario Canada
I finally got mine working. These are the files (use the same naming convention): 1- , 2-PFTAUSW-100318U.PGM , 3-PFTAUSW-100614U.PGM , 4-PFTAUSW-110302U.PGM , 5-PFTAUSW-110509U.PGM . Once you have these files loaded to your USB Stick Follow these instructions to a "T":
Do Below W/O Weather Forecaster Connected
Factory Reset - Load File # 1 - 1-PFTAUSW-Cleaner-U.PGM
Factory Reset - Load File # 2 - 2-PFTAUSW-100318U.PGM
Factory Reset - Load File # 3 - 3-PFTAUSW-100614U.PGM
Factory Reset - Load File # 4 - 4-PFTAUSW-110302U.PGM
Factory Reset - Shutdown Using Rear Power Switch
Connect Weather Forecaster
Enter Menu
Go To -- Installation - Go To -- Serial Update - Go To -- Network Setup
Go To -- SW Update -- Do this correctly as this is the most important part
Load File #5 -- - 5-PFTAUSW-110509U.PGM (generally the latest program available)
Factory Reset
Enter Menu - Go To -- SW Update
Factory Reset
Setup -- Satellite and LNB Diseq Setting
Channel Scan
