I-link IR210 Help, channel list and transponders ?
Username: Viperpiper
Post Number: 14
Does anyone know how to update the transponder list on an i-link ir210. Everytime i scan I seem to be missing channels for example, I'm missing 501 to 526. I've been looking for an updated transponder file or channel list with no luck so is there a way to update the transponders yourself.
any help appreciated.
Diamond Member
Username: Nydas
Post Number: 20250
I don't know your receiver, but in general a blind scan will get all the currently available transponders.
Username: Bazuka2020
Post Number: 976
Sometimes blind scan won't work you have to scan the tp and you can have all the current tps from lyngsat.com
Username: Chevrolet
Post Number: 334
Mr. P Channels 503 thru 532 are PPV
@ EchoStar 11 at 110.0°W
If this is what you looking for try these TPs
12239 H 20,000 7/8
12326 H 20,000 7/8
12414 H 29,000 7/8
12443 H 20,000 7/8
Username: Krishrgmxcom
Post#462
Post Number: 95
