DVD/VCR Set Up
Username: Jimboy311
I have a Magnavox DVD/VCR recorder. On the timer recorder
[Magnavox DVD/VCR] The programming numbers, only go to
125. With Dish The number go a lot higher. Can I get around
this? Or will this require I get a diffrent type recorder to
go with my Dish hook up? I just installed Dish,not very good
with the remote yet. I tried Dish help,no help there. Thank You
Username: Ieee488
Post Number: 458
Did you do an Autoscan for channels?
And do you see all the channels that you see if you used the Dish box's tuner?
Username: Samijubal
Post Number: 4290
You can't get satellite channels with a DVD recorder tuner.
Connect the sat to the DVD with s-video or RCAs and use the sat receiver to get channels.
Need to Register?
Forgot Password?
Enable HTML code in message
