Bronze Member Username: John_mosbyVirgina USA Post Number: 39 Registered: Jul-09 | My new PC came pre-load with windows 7 How can I change to windows XP thanks |
Gold Member Username: DoreenakadjCanada Post Number: 4787 Registered: Dec-06 | You can try this Windows 7's XP Mode http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars 3 steps download page http://www.microsoft.com/windows/virtual-pc/download.aspx |
Gold Member Username: DoreenakadjCanada Post Number: 4788 Registered: Dec-06 | or you could start from scratch with a formatted Hard Drive and install XP If you need help with that I will post step by step instructions for you. Just let me know. |
Platinum Member Username: NydasPost Number: 19829 Registered: Jun-06 | If you have Windows 7 Home addition, the following is a no cost method of adding windows XP to your current hard drive where Windows 7 Home Edition is installed. Good for Hrad Drives over 80 GB. Don't try on smaller drives although it may probably work even on 40GB drives. 1. Do a back up of important files on to a USB drive. 2. Download EASEUS Partition Master Home Edition - Free! 3. Read the insturctions and install it. 4. Move all your files to the lower end of the drive using the software. 4. Split the single partition on your hard drive into two or even three sections. 5. Shut the computer down after exiting. Now you can instal the WinXP in one of the newly created partitions. Your Win 7 partiion is still fully functional with the Windows 7. If you have the Win 7 Prof or Ultimate, Easeus home edition does not work with it, and you will have to buy the Professional edition of Torrent it down. Happy installing. |
Silver Member Username: VittuPost Number: 421 Registered: Oct-07 | before doing anything make sure XP drivers are available for your pc manufacturer. |
Platinum Member Username: PlymouthCanada Post Number: 14957 Registered: Jan-08 | Gray Ghost List your model! |
