New member Username: Asteroids
Post Number: 2 Registered: Apr-10
Posted on ping: unknown host www.iksprivateserver.com Is it dead? |
Platinum Member Username: Nydas
Post Number: 19834 Registered: Jun-06
Posted on I got though to the main site without difficulty. I have had problems in the past and found that others had not difficulty whatsoever. |
Silver Member Username: Guru4u
El Centro,
Cali Baby
Post Number: 443 Registered: Mar-10
Posted on Nalo said : I got though to the main site without difficulty. I have had problems in the past and found that others had not difficulty whatsoever. } |
Gold Member Username: Saqeeb9000
Post Number: 7306 Registered: Oct-07
Posted on working fine here http://iksprivateserver.com/ |
