Sonicview Public servers are down - No public IKS. If you want private IKS, you are best off using sada's help. At a cost of about $42/year, you might consider it a good reisk. He does not and cannot guarantee anything. IKS is an up and down service. Broken service is usual. If you can live with that, then do for it.
Captain Hook, are you a ho*ker? Captain Hook, are you a ho*ker's agent? Captain Hook, are you white hawk's agent? Are you Ecoustics lawyer? Do you receive a commission on interuppting all the threads and answers?
If your answer NO to any of the above then why don't you just buzz off to your Greg Raf and Cooler King?
