Cable Splitter for Basic TV
Username: Tpence82
Hello
I've split the cable that's coming in to two tv's. The problem I'm having, on both tv's, is any channel lower than 11 don't come in at all. I mean I receive them, but it's pure snow or at best, it's outlines of whatever is being shown underneath all the snow. Any suggestions?
Any help will be appreciated.
Thanks in advance!
Username: Ieee488
Post Number: 448
If you don't use the splitter is the signal clear?
Username: Tpence82
Yes & I have to use the splitter to my father's tv because for some reason there is no coax to plug into his tv coming from the wall anywhere in his bedroom.
Username: Ieee488
Post Number: 449
Signal will degrade.
If you are running a long cable to your father's TV from the splitter, then that is most likely the problem.
You might want to think about buying a signal booster
http://www.google.com/products/catalog?client=ubuntu&channel=fs&q=tv+signal+boos ter&oe=utf-8&um=1&ie=UTF-8&cid=2017003509719043665&ei=wgGVTM7IAYL7lwe1rpSnCg&sa= X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDcQ8wIwAg&os=reviews
Need to Register?
Forgot Password?
Enable HTML code in message
