still no luck.. i am trying this method..may be this will work..
1 - Connect the receiver to network and do factory reset and then make sure Dm100 has IP. 2 - Any PC that is connected to same network install a Free FTP server software, I recommend XlightFTP server 3 - After installing the Xlight FTP server on PC, create a username/password for the server 4 - Now that you have a FTP server ready on the PC with port 21. Create a folder and share that folder on the FTP server and copy the bin factory file on that folder. 5 - On Broken DM100 go to menu, Sw/update 6 - Change Domain to IP of the PC that is running ftp server 7 - Type username and password that you created on the server 8 - Press OK on S/W update 9 - It will scan the FTP server folder and show you the factory file. 10 - Select the bin file and press Ok 11 - Press YES to save changes and after 25 sec, the receiver will boot back into V2 mode
Now is more clear, You are trying a server ,go here for that and you need a program like this Software : Xlight FTP Server 3.5.5 RETAIL - http://www.xlightftpd.com/tutorial/activeDirectory.html
