Mitsubishi 72" DPL Mirror
Username: Ffriedlander
My mirror broke on a move and I can not locate another for my
WD-73737. Any suggestions?
Username: Plymouth
Post Number: 16510
Welcome to eCoustics Frank!
http://cgi.ebay.com/Mitsubishi-TV-Optical-Engine-Part-938P158030-/250767143269
Username: Magfan
Post Number: 2445
I THINK he's talking about the BIG rear projection mirror, which will be a bear to find.
LIght engines are readily available.
Username: Plymouth
Post Number: 16550
Ho sorry!
If it is the case the TV unit is good for the garbage!
I think the garbage is correct. It is the large mirror/screen set in just behind the screen that you can touch. A 73" piece of specially mirrored glass. Too bad it was a great TV. I did just install a new lamp, maybe 20 hours on it, that I will send to anyone for the cost of shipping. It will do me no good anymore. Maybe it could help you. Thanks for the input.
Username: Magfan
Post Number: 2457
A) Take out to desert. Remove lamp. Use for target practice
B) Recycle properly.
Need to Register?
Forgot Password?
Enable HTML code in message
