RTN
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 130
ok now that the VS ultra lite can't get it, does the cw600s get it ,if so what do i have to do to get it working thank you.
Username: Chaff
Post Number: 198
The cw600s ...when on rtn channel press page down on remote ..edit keys with red button...you will need to enter the 00 key only..select OK in the menu when done...you may have to do this ( page down and enter keys) twice, as the first time you enter keys it will be under nag2 and the second time it will come up as nag1 when you press page down..
