Sansui DTV2760, Samsung DVD-VR375, DirectTV DVR
Username: Pawsnclaws
Hello I am having a difficult time hooking up Sansui DTV2760, Samsung DVD-VR375, DirectTV DVR. I tried to call Samsburg they were unable to help me. I have tried so many different ways to hook this up to get it working, I have been unsuccessful.
I would really like to record movies/TV shows I saved on Direct TV DVR.
Can anyone help? Thank you
I have two red/white/yellow cables and S-video cable if that helps.
Can anyone help me with this ? Please Thank you
Username: Samijubal
Post Number: 4194
S-video out of the Direct TV into the DVD recorder, you still need the RCAs for audio. Set the DVD on whatever input you used. If there isn't an input key on the remote, go through the channels until you get to the right one.
DVD to TV should be, in order of preference, HDMI, component, s-video, RCAs. If using component or s-video you need RCAs for audio. The TV needs to be set on whatever input the DVD was connected to.
Need to Register?
Forgot Password?
Enable HTML code in message
