New member Username: MchittamPost Number: 1 Registered: Dec-09 | I have an Dish Network HD receiver. One T.V. is connected via component cables. Shouldn't I be able toI connect another T.V. using an HDMI cable to the HDMI ouput of the receiver? I've tried but get no signal?????????? Does the component connection cancel the signal to the HDMI ouput? Thanks |
Gold Member Username: RunnerguyPluto Post Number: 1964 Registered: Sep-06 | |
New member Username: MchittamPost Number: 2 Registered: Dec-09 | zulu; Are you saying I should use an S Video to RCA component adapter from the Dish Network receiver to the 2nd T.V.? Any ideas why the HDMI won't work? |
Platinum Member Username: PlymouthCanada Post Number: 12018 Registered: Jan-08 | ShamWow! Check in your receiver menu setting video output, you must have the choice between many outputs. |
New member Username: MchittamPost Number: 3 Registered: Dec-09 | Plymouth; will check tonight when I get home, though don't ever recall seeing that menu. Thanks |
New member Username: Batan_1Post Number: 4 Registered: Dec-09 | you can not use both of them ,only one output is alowed they cancel each others. |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 272 Registered: May-09 | ShamWow..Do NOT listen to plymouth ..He has his head up his azz |
Platinum Member Username: PlymouthCanada Post Number: 12019 Registered: Jan-08 | Jesus is a internet troll!!! Check his post and you will see that this guy is a idiot! |
Bronze Member Username: Nalinthe_retardKILLING FTA Post Number: 14 Registered: Dec-09 | Plymouth Platinum Member Username: Plymouth Canada Post Number: 12018 Registered: Jan-08 -------------------------------------------------------------------------------- ----------------- CHECK THIS AZZHOLES POSTS AND SEE WHO IS THE REAL IDIOT! |
Silver Member Username: Cheap_trickPost Number: 139 Registered: Oct-09 | Dish has different HD receivers for connecting either one or two HDTVs. If you have a legit subscription with Dishnet, best thing to do is have them change your receiver for a minimum extra cost. If you don't care about having independent control for each TV. then just buy a HDMI Splitter. (or Radio-Shack equivalent). |
