Motorola 6416 dvr programming
Username: Rexxer49
Recently purchased a motorola dct 6416 off ebay. It came from an unknown provider in california. I live in northern ontario with Eastlink as my provider. I had the box added to my account however the problem is that all of the guide information ( Tv stations, networks, time zone everything ) is wrong and wont update. I am wondering if anyone has any ideas as to how I can update the programming or software or something. I did the cold reboot, the Power menu DL and still the same.
Any suggestions would be appreciated
Username: Dylanger
call your cable provider, they will be able to tell you if your box is responding to their cable head end. Also have them send a cold hit to your box. In the event that it is a good box it should snap it right out of whatever it problem is.
Need to Register?
Forgot Password?
Enable HTML code in message
