Lnb
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 59
with this lnb
13/18 v daul output digtal ku lnbf lnbfd
input freq 11.7-12.2 GHz
output freq 950-1450 MHz
linear polarization vertical 10-15 v
horizontal 16-20v
Can i use this to take in AMC 5 at 79.0°W
with a view ultra light or if i hook it into the solaris either one works for me. I have a large dish to use also.
Username: Chumley
Post Number: 711
Yes
Username: Nydas
Post Number: 16706
Really...?
Username: Nydas
Post Number: 16722
It seems you have a dual output Starchoice LNB. You will need a DTV style 2x4 or 3x4 multi-switch.
Even then you might be wasting your time. A proper LNB for the job is what you should get for $20.
Post Number: 60
I already have sat 119,110,91 working on my switch it, 4 in switch, can i use this or what sat is good for Horse racing
Username: Pirate_pete_209
Post Number: 110
laughlin
like Chumley told you what you already have will work, don't waste your time or money.
Post Number: 111
Horse racing, the only one that I know now that is
Free to Air is @ AMC 5 at 79.0°W
(tp17) Freq. 12177 H SR 20,500 FEC 3/4
Username: Chumley
Post Number: 717
Horse racing OTB channel moved to 105w, use to be at 79w, also the Racetrack TV Network at 95w can be viewed with the right receiver and keys - info is here, under nagra1 95w
Username: Dibblydooda
Post Number: 88
If you have a combo LNB linear / circular you will have separate linear and circular outputs to hook up to your diseq switch then you should be able to choose a different LNB setting from your reciever when you scan channels.
For example when you scan 119W which is circular. The setting on your receiver might be LNB1, but when you scan a linear sat like 79W it maybe LNB2. It depends on how you hooked the LNB up to your diseq switch and your receiver type.
I have an Invacom QPH-031 LNB and a Capitive Works 700S so your results may vary.
Username: Nydas
Post Number: 16725
The switch you have is a 4 to 1 switch for circular LNBs. You have 119, 110, and 91 on it, so there is one input left. You cannot use a linear LNB on that input.
Get a $15-20 Ku band LNB with a LNB frequency of 10750 or less. Even a Digiwave 1189 (intended for 118-119) will work.
You can try Chumley's suggestion, if you want to and then you will know that "not seeing is believing".
Q.E.D.
Username: Nydas
Post Number: 16726
Captain Hook:
Enough of Hero worship.
This forum is for receiving or imparting knowledge.
Take your hero worship elsewhere, and STAY OUT OF THIS DISCUSSION.
Username: Nydas
Post Number: 16728
laughlin:
http://www.ftabins.net/showthread.php?t=13020
Make sure you read the post of the Super Moderator: Grandpooba which is right at the bottom.
Username: Chumley
Post Number: 718
NALIN THE CLOWN
He wants to get linear sats, not dn or bev which he already has connected to his switch.
Laughlin, I use the same setup 3 circular lnbs and one linear on a motorized dish all connected to a 4-1 diseqc
Username: Plymouth
Post Number: 11760
Chumley
I can understand now why you don't get east satellites, I hope that your Linear LNB is in the center of your dish!
Username: Chumley
Post Number: 719
I have 3 dishes , dish 500 , 300 and 30" w / linear lnb and motor.
My post does sound like they are on same dish - but they are not.
Username: Nydas
Post Number: 16730
Chumley......Really?
I don't see his query that way.
He wants to see whatever free channels there are at 79W.
Post Number: 112
Nalin Nyda why don't you stop your stupid azz sh!t
and stop confessing people that come here for help
laughlin: ask a question and Chumley gave him the correct answer
In your post above you tell laughlin
a LNB frequency of 10750 or less. Even a Digiwave 1189 intended for 118-119) will work.
In his thread he said that he has a Linear LNB and wanted
to know if it would work on AMC 5 at 79.0°W
and Chumley told him Yes
You are also passing wrong info here by telling him that
It will not work on AMC 5 at 79.0°W or any otherTrue FTA satellite
Now get lost enough is enough for today
Username: Plymouth
Post Number: 11761
Chumley
OK it sound better now!
Username: Nydas
Post Number: 16732
Captain Hook:
I told you to stay out.
This discussion is not for schoolboys.
King: where are you? Can you throw some light on the subject?
Post Number: 113
Hey Chumley when did the Horse Race channels moved
from AMC 5 at 79.0°W? LyngSat still list them
You said they have moved to 105
Where, AMC 15 KU or AMC 18 C-band and
what TP? again there is nothing listed at LyngSat
on these two satellites for these Horse Race channels.
Username: Nydas
Post Number: 16733
Captain Hook: Don't highjack the thread.
If you want to ask question to Chumley, start a new thread.
Username: Chumley
Post Number: 721
Nalin , laughlin is also looking for horse racing channels.
horse racing OTB channel
AMC-15 Ku
11738 H SR 20500 4:2:0 SD QPSK
I think they moved on monday of this week
Username: Nydas
Post Number: 16734
Chumley: You and your buddy Captain Crook are looking for horseracing channels.
His post does not mention this.
"Can i use this to take in AMC 5 at 79.0i½W
with a view ultra light or if i hook it into the solaris either one works for me. I have a large dish to use also."
You are way out of line when you suggest putting the two outputs of a Starchice LNB with two outputs and two voltages into the only spare output of his disEqC. Don't suggest the impossible.
Username: Chumley
Post Number: 722
I gave a one word reply, never said anything about using both outputs...and laughlin is looking for the horse racing channels
laughlin
Post Number: 60
Posted on Friday, November 20, 2009 - 11:44 am:
http://www.satellite-connection-systems.com/satellite-lnb.html
Username: Nydas
Post Number: 16736
Chumley: Look at your post
Posted on Tuesday, November 17, 2009 - 10:45 pm:
Yes.
At the time you said he could use the Starchoice LNB you did NOT know that he wanted to use it for horse racing channels.
Don't circumvent the issue. You have had a tendency for a very long time to half read a question and answer without thinking.
What complicates the issue is your stubbornness to see reality when it is pointed out to you.
Stop B.S ing and start reading the question and answer it properly.
Username: Chumley
Post Number: 724
Nalin,
79w requires a linear lnb,, you give him a link to fta-bins , where a person has the same lnb and wants to get 119- granpooba tells him to get a circular lnb.- how does that help laughlin ?
I didn't need to know about horse racing , he could watch the color bar screen or telemundo at 79w - I don't care.
So take your own advice and read and try to understand the question before you reply.
Thanks and have a good day !
BTW.. laughlin, I erred when I posted that the horse racing channel moved from 79w, they are still there and at 105w also.
Username: Pulpfiktion
Post Number: 497
Hey Chumley!!!.....
U still hear!!!
U dont like yor friend at FTABUNS?
Ha Ha Ha
Post Number: 498
Q. with this lnb
horizontal 16-20v
LK answers - Use a Disc switch with three inputs occupied. Put the two outputs of yor Starchoice LNB into the last input and U will get it.
HA HA HA
Username: El_toro_the_great
NC USA
Post Number: 249
vengeance is mine saith the Queen of ecoustics
Post Number: 504
Haha;s......Whiskey,......LK...... and Ryerson
Little cheapy
Post Number: 505
Little cheapy
