Kbox Remote Issue After 212 upgrade
Username: Topy
Post Number: 149
I just noticed after upgrading 212, in sat list I am seeing @ dishnet which is fine for me nothing to do with any problem, but when I am pressing fav button on remote, receiver restart automatically, even I can't see the list of favourite, I tried to recreate fav with the new name but still don't see improvement, bottom line is fav botton is not link with fav instead rebooting receiver. any solution ,,, thx
Username: Topy
Post Number: 150
any one have the same issue after 212 upgrade? If you have any solution pls reply... thx
Username: Plymouth
Post Number: 11685
RK
Check this thread:
https://www.ecoustics.com/electronics/forum/home-video/601718.html
Nalin will test a thing that I gived to him to recover a Kbox receiver, wait and see if it work for him, if it work, try it and I don't see why it can't work for you.
Username: Topy
Post Number: 151
thx plymouth, I am on wait,,, thx again
Username: Saqeeb9000
Post Number: 6272
Rk all the problems u have with the bin
post it at official site of k1plus
so coders look in to it and create a new bin,...
Username: Topy
Post Number: 152
where I should post ? give me coders site ,,, lol
Username: Topy
Post Number: 153
Sada By the way u have k1plus I remember u mentioned before,, do u have the same problem after loading 212 or not?
Username: Junkyfunky1234
Post Number: 44
RK, If you do a system reset and rescan the satellites.. this problem will go away for sure... I have experienced the same thing after 2.12, and it went away after I did a factory reset from the system restore menu. A drawback is that you have to add channels to your FAVs again
