Silver Member Username: SumpPost Number: 805 Registered: Aug-09 | kboxforum .com NEW BIN FILE .. hot off press .. prodigy and Plus |
Platinum Member Username: PlymouthCanada Post Number: 11524 Registered: Jan-08 | Thanks sump! |
Platinum Member Username: PlymouthCanada Post Number: 11525 Registered: Jan-08 | Direct link: |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 196 Registered: May-09 | Please stop spamming on my site. Thank You |
Silver Member Username: Last__supperSo Is Plymouth Post Number: 177 Registered: Oct-09 | Kbox forum sucks. So does tour link Plymutt |
Silver Member Username: SumpPost Number: 806 Registered: Aug-09 | well i just trying to be helpful ... the other site listed does not even have the new factory file 1.80 listed that came out many days ago .. since you do not have any files here thousght that the Kbox users might be interested .. many fixes with this one .. also many SV stuff too sorry if i offend anyone .. |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 197 Registered: May-09 | ONE: 'You shall have no other gods before Me.' TWO: 'You shall not make for yourself a carved image--any likeness of anything that is in heaven above, or that is in the earth beneath, or that is in the water under the earth.' THREE: 'You shall not take the name of the LORD your God in vain.' FOUR: 'Remember the Sabbath day, to keep it holy.' FIVE: 'Honor your father and your mother.' SIX: 'You shall not murder.' SEVEN: 'You shall not commit adultery.' EIGHT: 'You shall not steal.' NINE: 'You shall not bear false witness against your neighbor.' TEN: 'You shall not covet your neighbor's house; you shall not covet your neighbor's wife, nor his male servant, nor his female servant, nor his ox, nor his donkey, nor anything that is your neighbor's including Satellite TV |
Silver Member Username: SumpPost Number: 807 Registered: Aug-09 | oops ten is out the door ... do u hear confessions ?? guess #8's a loser too .. well now reading it a little more my KBOX is #2, if i did not carve it is it ok ?/ |
Platinum Member Username: PlymouthCanada Post Number: 11526 Registered: Jan-08 | sump You says that currentbins doesn't put the latest file came out , sorry I doesn't know, usualy they put all new files. Thanks for the the info, I will check it in futur. |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 198 Registered: May-09 | New this year online confessions: http://www.confessions.net/ |
Silver Member Username: SumpPost Number: 808 Registered: Aug-09 | or you are welcome to come u know where and get it anytime ..or check for latest ones .. i do not have SV but lots of stuff there .. |
Platinum Member Username: PlymouthCanada Post Number: 11527 Registered: Jan-08 | sump I checked many satellites files providers sites and it seem that they don't renews the files and leave their sites without any support. Not good at all for FTA! |
Silver Member Username: SumpPost Number: 809 Registered: Aug-09 | do not understand .."renews" |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 199 Registered: May-09 | As of 1/1/2010 pot smoking, bikinis and swearing will no longer be sinful. |
Platinum Member Username: PlymouthCanada Post Number: 11528 Registered: Jan-08 | sump I mean post latest files or update the latest files! |
Bronze Member Username: Cheap_trickPost Number: 18 Registered: Oct-09 | Jesus, if you don't stop to post your idiot post maybe Plymouth can ask to Admin for BAN you |
Silver Member Username: SumpPost Number: 812 Registered: Aug-09 | that funny .. |
Gold Member Username: Saqeeb9000Post Number: 6212 Registered: Oct-07 | don't download 210 files it has constant rebooting issues |
Silver Member Username: SumpPost Number: 813 Registered: Aug-09 | no ...i have tried this file and it works for me with NO problems ... it is already set to 'network" .. yes au needed to be turned off .. i have had file running 4 hours .. |
Silver Member Username: Last_supperRush is a HO-MO Post Number: 200 Registered: May-09 | I cannot get bandit because I have been advertized |
Silver Member Username: SumpPost Number: 814 Registered: Aug-09 | I admit i did not try the NETWORK page .. .. .. i apologize, this morning i went to network page .. it did reboot, once rebooted i have no OTHER problems to report ... I tried to twice 2nd time quick went to static .. no change rebooted .... so yes Sada that seems to be issue .. only if u need to be there .. i am wondering this my keep people out that do not know whatzz up and may have fixed other things so no need to go there now?? |
Platinum Member Username: NydasPost Number: 16453 Registered: Jun-06 | Thanks Plymouth. I got k1pro_210_20091101.zip from They always have the latest files for all receivers and you do not have to register. |
Silver Member Username: SumpPost Number: 815 Registered: Aug-09 | but you have to register here though ...... |
Platinum Member Username: NydasPost Number: 16459 Registered: Jun-06 | Sump: This is what Plymouth posted. do you have any issue with it? Direct link: Next time you are posting, please remember to post 2-3 sites for files. One member here was heavily criticized for posting URLs to his own site only, and had to stop posting altogether. |
Silver Member Username: SumpPost Number: 819 Registered: Aug-09 | at the time there were only 2 sites that had file ... i think u will find how 2nd site got it .... and check the times that file was uploaded ... as each site .. I merly was giving heads up to your users .. also i was pointing out that here also you need loggin ... also i did not see your 2-3 sites posted for downloades ??? as only 1 link works .. so is it bad thing that u need login ? That all i was saying it appeared to me that ? that is how sites MODERATE ... |
Platinum Member Username: NydasPost Number: 16461 Registered: Jun-06 | I am not on for or against caution as far as your personal identity or IP address goes in relation to IKS. However, some people do feel strongly against showing their identity to some sites and prefer not to have to log in. |
Silver Member Username: SumpPost Number: 822 Registered: Aug-09 | FYI ... the loggn .. has nothing to do with IP address .. Guest IP's are shown to admins all day long ..you do not have to loggin to have your IP shown just being at the page ANY page and it is shown ... ANY site uses the that information that is how it works .. someone posted the stats for this site "traffic" that is "guest" and "loggins" to get that information ... called viewing the pages ... |
Platinum Member Username: NydasPost Number: 16462 Registered: Jun-06 | You will find dozens of posts in this forum alone of fears of sites being taken oven by DN and logging details monitors and stored. As I said before, I do not have an opinion one way or other, but do recognize the concern of some members who would want to avoid logging in into a site dispensing files. It is therefore very relevant or even pertinent that members have access to sites where they do not have to log in for obtaining files. I have already expressed my personal opinion about it so I cannot go into discussion promoting views of one side or the other. You should look up those threads where they have discussed in detail the pros and cons of giving a login - even a false one. |
