KBOX prodigy status
Username: Baluja
Post Number: 186
Is Kbox up? mine is showing red light on khub
Username: Hardwarecrazy
Post Number: 91
It has been down since late last night (13 Sep).
Username: Sjain80
Post Number: 180
well it's working for me..My daughter is watching noggin at 169..tested usa network also...turn off your receiver and turn back on..should solve that problem.
Username: Ditzychic
Sebringville, Ont Canada
Post Number: 10
Mine down too. Tried turning off and on but nothing message "module is not connected" ?
Got Prodigy. Any one else got this problem? Does anyone know how to fix or is it IKS?
Username: Guanajuatos_best
Post Number: 280
Working perfect for me.
Currently watching hispanic music Videos.
Channel 870, 868, 867, 838, and 872
Username: Baluja
Post Number: 187
If i ping that IP address which is assigned for khub, I can ping it therefore for sure its not the home network. Any suggesstions or ideas
Username: Ditzychic
Post Number: 11
Mine is still out does anyone have any suggestions please? I have tried reset, I have tried rescan
Post Number: 92
Have the exact same problem on Prodigy as well
Post Number: 281
Im no expert, but I would say install factory bin and do all the set up again.
Make sure you do a system restore on the box.
Just hope to help
Username: Saqeeb9000
Post Number: 5983
just un plug and plug back ur hub,
this should work it for you,
make sure you are on netwrok mode
Post Number: 94
Sada, mine does the same since last night. It was working perfectly all along. It is still down. Using the latest (Sep 9) 203 file for Pro. Also, can you explain why currentbins dor com has 3 red faces for KB Pro?
Username: Baluja
Post Number: 188
Mine is on network mode. If so many people facing same issues, there is something wrong.
Username: 5355
Post Number: 27
Ya I had to reactive the K-Hub too and it worked great for me dod bless
Username: Kbox
Post Number: 33
reactive the K-Hub
Username: Ditzychic
Post Number: 12
I have unplugged the hub plugged back in nothing still same message" module is not connected" have in network mode I have shut it down for a couple of hours and booted it back up still nothing I am also using 203 file (Sept 9)
Username: Kbox
Post Number: 34
sam reactive the K-Hub
Username: Ditzychic
Post Number: 13
tried that nothing
Username: Ditzychic
Post Number: 14
how do you reactive K-Hub just unplug and plug backin that is what i didwas this correct?
Post Number: 95
SAM: After struggling just like you - I found the solution:
Go to http://kboxkhub.org/
Download K-Hub Activation 2.0
Unzip the files to your USB Stick.
Put the KBox OFF, then plug the stick into your receiver and then power the box ON.
The box will show the directory of your USB Stick on the TV Screen.
Then navigate to the file FT_a1.25_up(p).rom and press OK on your remote.
It will copy the file to your receiver - do not power the receiver OFF during this time.
Now after it completes, it will automatically reboot.
Now go back to same Website and download and install the latest file203-20090909 for your receiver.
Now you are good to watch TV to your heart's content!
Username: Ditzychic
Post Number: 15
it worked great thanks Hardware you rock
Username: Ennio
Post Number: 69
SAM
Turn rec.off remuve Khub and cable reinstal Khub and cable load file Khub activations v2,00 "Khub.rom"
wach tv !!
Username: Baluja
Post Number: 189
I re-activated the khub and it worked. thanks everyone.
Post Number: 5985
Rakesh good to hear that..
i think only pro's had this problem.. with new bin,
Username: Justforhahas
Post Number: 1847
Nice to see people helping each other for a change..with no bashing or arrogance...now thats what this hobby is all about...and this site should be like all the time..good teamwork guys...
Username: Vap
Post Number: 41
k1 dead
by mistake I turn off my box went Upgrade ande them the box shut dowm and no lights on display!
any sugestions.
thank you.
Post Number: 5986
joca can u atleast see the message h1 or something like that..
Username: Vap
Post Number: 42
yes I see H1 and then desapear.
Username: Plymouth
Post Number: 10955
justforhaha's
Happy to see that you appreciate.
Username: Kbox
Post Number: 35
i am glad to see every one up
Post Number: 5988
c&p from dssrookie..
joca u need a serial cable in order to do this..
if u have plus use the one that u use for khub..
i am not sure if pro comes with serial cable.
this will only work with serial /loader cable
If your receiver has a H1 error on your led display, this is how to fix it.
1: Down load factory file and K1 Plus loader and unzip the following.
Link for Factory File:
http://www.dssrookie.com/forums/b-fo...le-223630.html
Link for Factory Loader:
http://www.dssrookie.com/forums/b-fo...er-223627.html
2: Connect RS232 cable to the receiver and plug the power cord
from the receiver into the wall with the main power source off
on the receiver.
3: Open the loader on your desk top. Locate the factory file
with the browse button on the loader.
4: Now have your finger on the rear power button. Click it
to the on position. When you see the H1 error appear on
the display. Click CONNECT on the loader immediately. This may take a
few tries but the receiver will eventually accept the file.
5: Load the latest file and reconnect the receiver back up to
the your t.v.
6: Adjust all your dish settings and your good to go.
__________________
Username: Kbox
Post Number: 36
Username: Vap
Post Number: 43
thank you sada.I got it, But I find the problem after all. The box is was on standalone MODE!
Im Idiot. thank anyway.
Post Number: 5990
so how did it work for you joca?
did u try the obove steps because u said box won't even turn on,
so how did u switch to network mode,if ur rec can't even turn on..
just curious..
Username: Vap
Post Number: 44
yes sada I did the steps you told me.
But every time you put the Factory bin,you have to change from Standalone mode to Network mode,that why
before dont work.
