New member Username: Dwd75Post Number: 1 Registered: Aug-09 | WHY I NEED TO REBOOT KBOX Pro MOST OF THE TIMES? Every now and then if I want to see TV I need to turn power ON/OFF, goto 200 wait and go back to channel you want to see. I mean everytime I have to play around in order to watch TV. any IP issues? or something like that? |
Silver Member Username: JaysonPost Number: 373 Registered: Aug-06 | it should be your internet connection....do you have it connected on slot #1 on your router??? |
Bronze Member Username: LoverboyzPost Number: 68 Registered: Aug-06 | DWD75 is right... I have to reboot my kbox very often compare to my nova..Kbox does have lot more freezing problem than nova... No complains though... I m loving my kbox and my nova till they last. |
Bronze Member Username: Abe125Cali Post Number: 27 Registered: Sep-06 | just like the internet ... there always break in the connection.... .... until they come out with a n3 fix .. its a small issue to deal with... |
Silver Member Username: RescateVENEZUELA, M... Post Number: 404 Registered: Nov-07 | yes, but not a big deal, my kbox is always unpluged unless somebody at home want to watch. But once pluged runs flawlessly all 3 to 5 hours or until I unpluge it again. Regards |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4373 Registered: Oct-06 | Actually many servers are set to kick your IPA if yo don't touch receiver's remote control for 4 hours It is set automatically by server's administrator 3 to 5 hours Very common in IPTV and even Digital CableTV It saves bandwidth by limiting traffic to main management server Solution: Just change the channel up/down and wait 30 to 60 seconds until it comes back No need to turn off receiver Sometimes it will take few longer minutes if there is a Key roll over in addition your IPA kicked off the server Let me know how that works for yo Remember many server admins set to as low as 3 hours if yo don't touch remote for that long |
New member Username: Dwd75Post Number: 2 Registered: Aug-09 | K.Tape Thanks for the input, now I am satisfied as I am not alone rescate is right, once I start watching then it works fine. problem only comes @ startup. |
Platinum Member Username: NydasPost Number: 15960 Registered: Jun-06 | King Tapeman: I have used atomic clock in the past to fool the ISP that I am active and they stopped kicking me out. I don't think atomic clock will work against the IKS servers but is there a similar technique available for IKS servers? |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4374 Registered: Oct-06 | I don't think there is an easy way around it If they don't set timeline on users hosting servers can crash all the time There might be a way around it but that can cause hosting server to crash easier I wouldn't doubt if D#N or B#V try to bring down traffic to cause the interruptions This is how it works: Let's say data exchange rate is 56kbps Hosting Server pipe line is 50Mbps download 1000 users can easily crash for exceeding maximum capacity or you start bumping users 56k x 1000= 56Mega higher than 50M max capacity Problem can be corrected by both adding more hosting servers and pay for more bandwidth As yo can see it's all up to server provider and how much are they willing to spend Providing constant data exchange from server to receiver consumes bandwidth and that means money |
Platinum Member Username: NydasPost Number: 15967 Registered: Jun-06 | "Problem can be corrected by both adding more hosting servers I was under the impression that they use many servers with UDP protocol |
Bronze Member Username: HardwarecrazyPost Number: 88 Registered: Dec-07 | I think there are too many ignorant posters in this forum and more than that, many 'smart Alecs' who think they know everything. First of all, all Internet connections (IP) are called 'connection-less protocols'. In other words, once the data is fetched, the connection automatically terminates and waits for the next internet request. This is how internet works. So the server is never connected to any single fetching computer for ever. Just for a few Milli secs. That's it. This applies to KHUB, IHUB which use Internet Protocols. |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4375 Registered: Oct-06 | Wow So updating keys is a one time fetch? according to your ignorance Internet Request? Wow wow I never heard of that terminology before Yo got a lot to learn PAL Just keep on trying |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4376 Registered: Oct-06 | Also there is a good way to test it Disconnect the Internet connection And see if it works Mr. Hardware |
Bronze Member Username: SumpEast coast USA Post Number: 87 Registered: Aug-09 | hardware is on the right track .. it is TCP/IP there is TCP traffic and IP traffic also if you watch the little lites u can see how often packets requested and recieved. for the more deserning user you may be able to look at you router and see the packets ..how big how often also there are more programs that will break it down even futher, if i remember correctly in XP Pro you can set up your netcard to be permiquuios ( bad speller ) and see the actual traffic. it is very low, see small amount |
Bronze Member Username: HardwarecrazyPost Number: 89 Registered: Dec-07 | King Taperman, the more you write, the more you show your ignorance! So take the clue and write only about things you know. Obviously, TCP/IP, Internet etc are not your cup of tea, brother! So take the clue from Sump and melt away! |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4377 Registered: Oct-06 | So disconnect the RJ45 and see if it's required or not? It's so simple to try FYI Any protocol requires Address and Data Therefore there is a rate of Kbps modulated as pulses Even if it's 1-packet Go ask a real hardware expert But that will be me Sukka |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4378 Registered: Oct-06 | |
New member Username: Dwd75Post Number: 4 Registered: Aug-09 | hardware accidentally jumped into FTA discussion without any knowledge of FTA. I wouldnt blame him as it is not his fault |
New member Username: King__of_satsPost Number 998 Post Number: 1 Registered: Aug-09 | King your the Man these other two Idiots have no clue. |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4379 Registered: Oct-06 | It's the same ignorant His Englic easy to spot I don't mind teaching retards I love retards The guy wouldn't answer a simple question Is the internet cable required at all times or not? If it's not required then it doesn't consume bandwidth If it is required then now he learned how servers crash Don't talk about Nimda I still got a crush on Jimmy |
New member Username: Us_marshallPost Number: 6 Registered: Nov-08 | King Tapeman says, I still got a crush on Jimmy They did say that you were G@y thats your business Please keep it to yourself this forum is not a place to post this kind of stuff. |
Gold Member Username: RiconissanPost Number: 1922 Registered: Feb-09 | |
Bronze Member Username: SumpEast coast USA Post Number: 92 Registered: Aug-09 | the answer is yes ... 30 - 90 seconds appox ... then connect for 1-2 seconds i think that actually makes the opposing point ? i believe the DOS has to do more with overloading the server processing/memory than bandwith bandwidth throttles are before the server, set at routers @ the ISP's |
New member Username: King__of_satsPost Number 998 Post Number: 2 Registered: Aug-09 | |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4380 Registered: Oct-06 | "the answer is yes ... 30 - 90 seconds appox ... then connect for 1-2 seconds i think that actually makes the opposing point ?" Now that yo at least agree that a constant connection from Khub to yor router must be ON at all times That's progress The next step is figure out what bit rate is required? Usually is adjustable rate set by hosting server but has to be set to a specific fixed level Another word adjustable but not variable If I'm in NY and I call California for 1 hour During this one hour I only spoke 4 words If i'm billed 5 cents a minute Can I call my long distance carrier and tell them I hardly spoke few words? I need a break on the price What do yo think the reply will be? Do yo see my point now? If there is an open communication between two terminals on a deticated line there must be a constant bit rate Mbps or Kbps Multiply that by number of instant users yo'll get yor maximum capacity of bandwidth That's basic stuff protocol 101 Look Yo accept my answer or not That's up to yo I explained to DWD75 how he gets kicked out Hardware has no clue what he's talking about |
Bronze Member Username: SumpEast coast USA Post Number: 94 Registered: Aug-09 | i had no problem with the all iks = internet connection .. where my questioning is that there is a CONNECTION it is not dail up modem make connection untill you get kicked off or log off ... So from what you said then ... when you type in a new website that you have not been to for awhile and you browser contacts the 3-9 DNS servers to find out the ip address of www.ggg.com then it stays connected for hours ?? NOT .. it is just a simple transmission and answer VERY similar to dns .. if i remeber correctly and could be wrong it is UDP for the IKS stuff .. " CONNECTIONLESS" |
Bronze Member Username: SumpEast coast USA Post Number: 95 Registered: Aug-09 | ok can't resist ... http://en.wikipedia.org/wiki/User_Datagram_Protocol |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4381 Registered: Oct-06 | I never said dial up I said deticated line And it;s on all the time There is a constant refresh Therefore there is a constan exchange on a constant bit rate per second Deticated Line yo got unlimted usage But Server owners pay per Mega Bit Per Second THAT'S BASIC SH!T |
Bronze Member Username: Last_supperNazerith , Isreal Post Number: 89 Registered: May-09 | |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4382 Registered: Oct-06 | This is Yo Mama Aribian Boi |
Bronze Member Username: Last_supperNazerith , Isreal Post Number: 90 Registered: May-09 | |
Silver Member Username: Master_leePost Number: 198 Registered: Oct-07 | sump I wouldn't waste any more of your time with that guy he is as nutty as a fruit cake. Two years ago he was going to show everyone here how to make free phone calls any where in the world by satellite. |
Bronze Member Username: Last_supperNazerith , Isreal Post Number: 91 Registered: May-09 | sump....King has not got both paddles in the water and lives in a cardboard box in Brooklyn NY Citay Yo! |
Bronze Member Username: Last_supperNazerith , Isreal Post Number: 92 Registered: May-09 | |
Bronze Member Username: SumpEast coast USA Post Number: 96 Registered: Aug-09 | ok thanks !! |
Bronze Member Username: SumpEast coast USA Post Number: 97 Registered: Aug-09 | ok thanks ! kboxforum.com |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4383 Registered: Oct-06 | Doesn't matter how many nick names yo use Yo'll always be an insecure faceless coward aribian terrorist 14 year old child This is yo mama |
