I bought NFUSION SOLARIS please help to install
Username: Snagovac
Post Number: 153
Today I bought nfusion Solaris I tried to install I did not know I have and powerline networking turbo85 Mbps if someone knows please for help
Username: Plymouth
Post Number: 10418
Damir
Load this file in your receiver:
http://currentbins.com/nfusion/Solaris/
Do a factory default then scan your satellites.
Normally you only hook your turbo85 in your rooter and your receiver.
In your receiver press menu/internet and use this setting:
Internet connection: "ON"
Auto Update Check: "OFF"
Network Information:
DHCP/Static: DHCP
IP Adress: 192.168.001.100
Subnet Mask: 255.255.255.000
Gateway: 192.168.001.00?>> Rooter port 1 use 1, port 2 use 2 etc.
PVR Server IP Adress: 255.255.255.255
Note that these settings must come itself, if not put it manualy.
Good luck!
Username: Snagovac
Post Number: 154
PLYMOUTH which loader to use and how
ate the same as in the PANSAT or flu or something else
Username: Plymouth
Post Number: 10420
Damir
here is the loader:
Username: Snagovac
Post Number: 155
nothing has helped on my tv, writes SERVICE NOT AVAILABLE
what I did wrong, I put the new bin
Username: Plymouth
Post Number: 10423
Damir
After that you loaded the bin, you must do a factory default then scan your satellites.
The factory default is very important.
Username: Snagovac
Post Number: 156
I am all the time try to find a factory default where the
Username: Plymouth
Post Number: 10426
Menu/System settings/Factory default
Username: Snagovac
Post Number: 157
when i go on menu and i press system settings i get on the next page-
language settings
tv stadard
time adjustment
time settings
tv aspect ratio
multi-ch audio out
s/w version
initialization
i dont see factory default on here please tell me where to get factory default please help thank you
Username: Plymouth
Post Number: 10428
Damir
Press s/w version and give me the program version
Press Initialisation(factory default)
Username: Snagovac
Post Number: 158
S/V boot R3x 1.30:3f73554e b84ab9ef
s/w x 1camcubn20080_u37:80230692
crc is correct
Username: Snagovac
Post Number: 159
i put bin 151_3 and i pressed on initialization and i dont know if this is a good bin or do i have to only ut this bin in the reciever or maybe a factory bin but i dont know which please tell me what i am supposed to do i have 2 powerline networking i ut one on linkys the other one i put in the reciever and i put the bin 151_3 that is what i did what do i do next
Username: Plymouth
Post Number: 10431
Damir
You must see it: boot R3x 1.30 Software ver: 1.53.3 DIP 0.77
Reload the bin file and when you will see this version do a factory default then scan the satellite.
Try a hard reboot before.
Username: Snagovac
Post Number: 160
when i press internet in menu i get network information
dhcp/static DHCP
ip adress 000.000.000
submit mask 000.000.000
gateway 000.000.000
PVRserver ip adress 255.255.255
Username: Plymouth
Post Number: 10433
Damir
Username: Snagovac
Post Number: 161
where can i find softwhere boot R3x 1.30 Software ver: 1.53.3 DIP 0.77
Username: Plymouth
Post Number: 10441
Damir
This is the good file: http://currentbins.com/nfusion/Solaris/
try to hook your box directly in your rooter.
Username: Snagovac
Post Number: 162
i already put that file in directly into my receiver but nothing is helping
Username: Ricocossan
Post: 1789
Damir you are a dummy
Username: Snagovac
Post Number: 163
Thanks Plymouth I dummy it's true I heard you and bought nfusion solaris now I need help and you said that I am the dummy
Username: Plymouth
Post Number: 10453
Damir
This false Plymouth is a troublemaker, look the post number and the username.
You are not dummy at all!
Username: Snagovac
Post Number: 164
well I have seen that it is false but please someone help me to run Solaris nfusion does anyone know what to do first I know nothing with this receiver
please help me and i have powerline bridge wireless my wireless is linksys broadd and router is 2.4 is this router good for powerline bridge
Username: Snagovac
Post Number: 165
nobody wants to help
Username: Plymouth
Post Number: 10456
Damir
You must have the good file in your receiver
Is OK now?
Username: Snagovac
Post Number: 166
ok I have the boot file R3x 1:30 software ver: 1.51.3 DIP 0. given channels but do not work for Service not available IP address: 000.000.000 what is not good
Username: Plymouth
Post Number: 10457
Damir try a hard reboot now on back panel and be sure that your proxy is to OFF
Sada give me this link for set Nfusion:
[link removed]
You have to login and if you have question ask it on this site.
Username: Tulipe
Post Number: 74
damir listen . what playmouth did with you no one would do it . he gave you everything you need . even if u pay someone he wont do it for you,
i guess u r too slow and expect to watch tv in blink of eye
go read in sites that has solaris read read read read read read read read read and will make ur life easier.
Username: Rafiq128
Post Number: 207
I think he is not connected with internet, he is getting ip 000.000.000
Username: Plymouth_glasser
Post Number: 60
Bhatti----- if damir civic is not connected with internet
then how does he manage to post here?
Username: Plymouth
Post Number: 10465
Poor idiot, the receiver is not connected, not him
Username: Snagovac
Post Number: 168
am connected receiver powerline networking internet but how to be sure that I am well on the Internet
thanks
Username: Tulipe
Post Number: 75
go to school
Username: Snagovac
Post Number: 169
ok thanks think that you know something
Username: Plymouth
Post Number: 10487
Damir
Power off all, the receiver the router and the powerline network.
Now put On the rooter then the Powerline Network then the receiver and see if it work.
If it not work try it:
In this link: [link removed] you have few proxy listed put 3 of them in proxy space in the receiver and put the proxy to on and return on your connection and see if all the IP info are there.
In menu/internet you can try to download directly the file.
Try many options.
Username: Snagovac
Post Number: 170
plymoutht====thanks I will now try
