Username: Jryevols Little rock,
Arkansas
Post Number: 116 Registered: Mar-07
Tuesday, June 02, 2009 - 22:37 GMT I have a Pansat 3500SD and Pansat 9200hd , will they eventually get N3 or do I need to purchase new receivers. Is the nfusion currently working on n3
Username: Saqeeb9000 Post Number: 5132 Registered: Oct-07
Tuesday, June 02, 2009 - 22:45 GMT satman nfusion is working on bev nagra 3 channels while k1plus is working on dn internationals (currently on nagra 3 while sonicview also have Ihub using internet connection but currently there channels are freezing,as they will release new bin soon, all those rec's are working on iks
Username: Thoronto Post Number: 76 Registered: Jun-06
Tuesday, June 02, 2009 - 22:54 GMT Nfusion works on bev only and not dn? Also, if k1plus is the only box working with DN, does it wok for all international channels? thanks (-:
Username: Saqeeb9000 Post Number: 5133 Registered: Oct-07
Tuesday, June 02, 2009 - 23:18 GMT yeh almost ,which ones are u looking for on 118.8 they are only working on 118.8
Username: Thoronto Post Number: 77 Registered: Jun-06
Tuesday, June 02, 2009 - 23:40 GMT 61.5 brazilian channels, globo, record, PFC...just to confirm, nfusion is just for bev, right Sada? thasnks.
Username: Gregraf Post Number: 2936 Registered: Dec-07
Tuesday, June 02, 2009 - 23:45 GMT Yes Nfusion works for dishnet with N2 channels that havent gone to N3> Its been wide open for quite some time. When all Dish channels have switched to N3 and only after that u can be sure they will be up on Nfusion.
Username: Saqeeb9000 Post Number: 5135 Registered: Oct-07
Tuesday, June 02, 2009 - 23:49 GMT 61.5 is not working anymore,
Username: Thoronto Post Number: 78 Registered: Jun-06
Tuesday, June 02, 2009 - 23:54 GMT sorry, but do you mean 61.5 is not working anymore with which box? Nfusion, Kbox or both?
Username: Saqeeb9000 Post Number: 5136 Registered: Oct-07
Wednesday, June 03, 2009 - 03:17 GMT nfusion wasn't working with any internationals at nagra 3 at all, k1plus is only working on 118.8 so both are not up with 61.5 k1plus is up with 118.7 while nfusion is up with 82 west and 91 west
Username: Thoronto Post Number: 79 Registered: Jun-06
Wednesday, June 03, 2009 - 15:56 GMT What is 118.7 , is that when you use that other tipe of Dish and not the standard? Is 118.7 also dish? Kind of confused now (-: sorry.
Username: Saqeeb9000 Post Number: 5149 Registered: Oct-07
Wednesday, June 03, 2009 - 16:32 GMT yes thronto 118.7 is degrees like 148 degree, 61.5 degree u need bigger dish and special lnb in order to get 118.7 118.7/188.8 are same
Username: Thoronto Post Number: 80 Registered: Jun-06
Wednesday, June 03, 2009 - 17:00 GMT Thanks, that dish is a pain to set it up. thanks for the info.
