Pansat 2500A converted 103 and Bin 217
Username: Flemings
NALIN and All Other Gurus,
I have loaded bin 217 on a converted Pansat 2500 box. I got bad or scrambled channel for all channels. Does Bind 217 work? Do I need to manually enter the key or something? How many channels are still available to 2500A on Dish 119? I haven't watched Sat for 6 months. I am a little behind.
Thanks for all your help.
Fleming
Username: Flemings
Can anyone please help? Thanks.
Username: Geeljire
Hello, please I need help I have Viewsat Ultra and all the channels are dewindeling day by day. all will be gone soon. I originally had Intelsat, nimiq1,3, ecco 9, 11 all the movies are almost gone now.
please help, what should I do?
Username: Nydas
Post Number: 15203
You should get channels on a blind scan. You can try manual key entry.
Username: Ricocossan
Post: 1289
Post Number: 7
Username: Geeljire
How can I manually key enter please help me how?
Username: Geeljire
Post Number: 7
and or where R the Keys?
Username: Nydas
Post Number: 15208
Musho Geeljire:
http://www.tvkeys.com
My original reply was directed to fleming. However, your problem is no different than mopst people watching TV on FTAs. Most of the channels are now goner over to Nagra 3 encryption, and what you are seeing is the remaining channels that are still under nagra 2 encryption. Therefore, if you are getting some channels, you do not have any problem to correct.
Username: Geeljire
Post Number: 8
how I can get nagra 3?
Username: Nydas
Post Number: 15211
8 posts and joined in 2006. I don't know where you have been.
You can't "get nagra 3".
Try and google "nagra 3" or "nagravision 3" and read.
You can even do a search on this site for this item and you will get tons of information.
Username: Nydas
Post Number: 15213
Here is an URL that will give you all the info for your needs.
http://nagravision3.org/faq/
Username: Nydas
Post Number: 15214
