When i go to the cw700 download section i see a few sticky, like: Factory file 1.03, 2.10 all new cw700 boxes from factory need to load this file, dead cw700 after BIN 1.95, first time install cw700 2008 added serial security... So how exactly do im suppose to set it up, I know the settings but when it comes to files wich are the correct file that i have to load first then second, ect. Remember this is for a brand new Unit that i got today, new generation.
2. a. Press and hold down the power button on the front of the box while turning back ON from the rear and wait till you see the word BOOT on the front display for 4 seconds then let go of power button. 2. b. . Using a 9 PIN SERIAL CABLE (NOT an USB PORT), Load Factory Bin file Version 1.02
3. a. Using cable or USB port , Load Bin file Version 1.91 or below (Optional) 3. b. Patch Enable - F1 followed by 000 3 c. Turn box off from rear
4 a. Press and hold down the power button on the front of the box while turning back ON from the rear and wait till you see the word BOOT on the front display for 4 seconds then let go of power button 4. b. Using a 9 PIN SERIAL CABLE (NOT an USB PORT), Load Bin file Version 1.93 and follow all of the Release Notes with that file. 4. c. Enter 9 or 10 Digit Serial Number Located on bottom of receiver 4. d. Do Factory Default again 4. e. Patch Enable - F1 followed by 000 4. f. Turn box off from rear
5. a. Press and hold down the power button on the front of the box while turning back ON from the rear and wait till you see the word BOOT on the front display for 4 seconds then let go of power button. 5. b. Using a 9 PIN SERIAL CABLE (NOT an USB PORT), Load Factory Bin file Version 1.03. 5. c. Do Factory Default again 5 d. Turn box off from rear
6. a. Using USB PORT (or a 9 PIN SERIAL CABLE ), Load Bin file Version 2.27 and follow all of the Release Notes with that file. 6. b. Patch Enable - F1 followed by 000 6. c. Turn box off from rear and turn it after 30 seconds.
7. Load Saved Channel List or Setup Sats and Rescan 8. Exit out of menu.
