Silver Member Username: Thakkar2000Post Number: 216 Registered: Jun-06 | My FLU (Pansat clone) had been working fine for a few months now with the LZMA conversion. But recently I loaded the 215 LZMA bin and my receiver is having problems. I turn it on, and the P.U.F.F rolls across, stops at F and then the box turns off. I tried both the Fwank7 JVVH 215 bin and the other Nikk JVVH and the problem is still there. I would appreciate any help... |
Bronze Member Username: McrabbycabbyWpg, Man Canada Post Number: 99 Registered: Jun-06 | try to reload it mine is working fine good luck. |
Silver Member Username: Getmo96Post Number: 120 Registered: Jul-08 | use 214, it is more stable |
Silver Member Username: McrabbycabbyWpg, Man Canada Post Number: 101 Registered: Jun-06 | i got some other boxes and the puff just kept rolling i found the tronics puff conversion tools at ftabins.net and followed the instructions my problem waswhen i loaded the 214 bin it didnt seem to want to work the bin that worked but froze was 201femu so now im wondering if only femu bins will work on these boxes? thanks |
Platinum Member Username: NydasPost Number: 15155 Registered: Jun-06 | LZMA is a different type of conversion than PUFF although LZMA is also known as PUFF-LZMA. Tronic 1.7GUI converts to PUFF, not LZMA. If you already had LZMA, you had 1.03 boot in your receiver. That will not work with PUFF installation. You can try 1.02 boot, and the tronic PUFF installation might work. Alternatively, you may try to install the current LZMA file from Fwank7. It will have word LZMA in it. You must have 1.03 boot Essential kit 103 for conversion to 103 LZMA boot Kit. PUFF_LZMA_215 BIN included PUFF_LZMA link Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Bronze Member Username: Rockman169Canada Post Number: 78 Registered: Nov-06 | so nalin is fwank7 lzma 215 working with out freezing thanks |
Bronze Member Username: Rockman169Canada Post Number: 79 Registered: Nov-06 | or should we use the 214 |
Platinum Member Username: NydasPost Number: 15156 Registered: Jun-06 | My understanding is that both Fwank7 and Nick Mty versions of LZMA_215 are working well. |
Bronze Member Username: ElvirmPost Number: 93 Registered: Sep-07 | Hi Nalin, I have some freezing on 215 |
Silver Member Username: Popol_vuhPost Number: 122 Registered: Jan-08 | 214... |
Silver Member Username: Popol_vuhPost Number: 124 Registered: Jan-08 | FEMU is different from LZMA... LZMA needs boot 1.03... t23, I would try to reload 1.03 boot bin. |
Platinum Member Username: NydasPost Number: 15157 Registered: Jun-06 | LZMA_217 is available last one hour or so. Essential kit 103 for conversion to 103 LZMA boot Kit. PUFF_LZMA_217 BIN included PUFF_LZMA link Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Thakkar2000Post Number: 218 Registered: Jun-06 | hey, my initial problem is fixed but now i keep getting scrambled or bad channel even with the new 217 bin...The signal is fine at 80% |
Bronze Member Username: Dinky_dauPoinciana, Fl Usa Post Number: 28 Registered: Mar-08 | p.u.f.f. lzma 215 started freez saturday night a few hour later nalin nyda said to go one bin back too 214 watch ufc,and its been working ever since. |
