Help pansat 2700 channel on w148
Username: Asifali418
Lodi, Ca Usa
Post Number: 178
i try to put PID by hand in pansat 2700 on w 148 on tp 12632 when i put pid for ary irs work great but in same tp when i put pid for q tv its delte the ary channel.same on 12603 can some one help me?
Username: Bazuka2020
Post Number: 656
After getting or scanning one channel change or rename the channel by going into channel edit than scan another one
Lodi, Ca Usa
Post Number: 179
i try the one too but no luck
Username: Chumley
Post Number: 218
If you send Rico your next BM , she will give you advice..
Username: Plymouth
Post Number: 9335
nike usa
try a hard reboot before add a new PID channel.
