Anyone missing channels
Username: Kellergirl
Orlando, FL
Post Number: 162
I have scanned several different times, and I am missing about 20 channels from 110 and 119. What am I doing wrong?
Thank you.
Orlando, FL
Post Number: 163
Ugh, never mind. I appreciate your help Plymouth, but my box is ALL screwed up. The sat was gone again, and I had to re scan 110 and 119, and ALL the channels say PROG. UGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am ditching this box and getting another one.
Username: Joeturn
Post Number: 555
its the files
Orlando, FL
Post Number: 164
So should I re-load the bin?
Username: Plymouth
Post Number: 9321
Kellergirl
Do a total factory default then load the factory bin from captiveworks.com then the latest bin.
Note that is possible you lose some channels with a scan because Dn had doing many change and few channels are lost.
Orlando, FL
Post Number: 165
Well, just a few I am missing is Baby First and VH1, among others. And I had them yesterday. I will try that Plymouth, thank you.
Orlando, FL
Post Number: 166
Plymouth, you are the man! It worked, many thanks!!!!!!!! :-)
Username: Plymouth
Post Number: 9324
Kellergirl
I' m so happy for you and your husband.
You are Welcome!
