if there are not working here are steps i normally do go to menu, network, sw version check, if u get s/w version, just do an upgrade, after finishing upgrading ,redlight's comes automatically, i tried it few times , first there was no red light comming, after doing upgrade, redlight came automatically (although i had latest version), if u can't upload, reboot modem router etc,
That was pretty handy. I didn't even know if we can update the s/w like this. I always used to use the null modem cable. They are working now except b4u & atn.
no way blue , i always update u guys u guys just have to read more, ok if u got time in hand here is something u can do, or when ever u are free, there are 4 ways to download the newest bin, one is old fashioned wa with null modem cable (boring) time consuming, the secound way is easiest using ur remote, go to menus, internet, sw version, swupgrade, thirdway is using webloader using ur laptop (wirelessly) or dektop computer [link removed] 4th way is using channel editor, this way u can save ur channel list and next time u can't lost ur channel list, and if next time if u had to do a factory reset / or u loose channel for some reason u can simply download ur channel list anytime u want, just make sure u don't open the list, u can also save add channel delete channels, add channels , add favorite channels, lock channels all through channel editor,
[link removed]
nfusion did a lot , they were the first one , always innovative, but right now they have to do major upgrading in order to compete,
