Transmit video/ audio wirelessly to tv throuh any website,
Username: Saqeeb9000
Post Number: 4817
what is a good software/device which is cheaper than jadoo tv and can transmit audio /video to hd tv
and u can watch video from any website on ur tv,
Username: Bernardmi
Post Number: 446
Why wireless sada ?
http://www.weethet.nl/english/video_connect_pc2tv.php
Username: Bernardmi
Post Number: 447
I would rather trust D-Link
http://www.slipperybrick.com/2008/01/d-link-pc-on-tv/
Username: Bernardmi
Post Number: 448
I am reading on the web that you should stay away from conventional wireless band (IEEE802.11) because of insufficient bandwidth !!!!!
You should try to find a bluetooth wireless link.
Ouchhhhhhhhhhhh.... that is going to cost a lot !
Username: Way2smart
Www.Desifta.com
Post Number: 1738
why not buy a apple tv?
Post Number: 4818
wireles becaue i don't like cables, and wires..
i use laptop so its much better.
thanks for links outer limits,
Username: Riconissan
Post Number: 878
sada a friend of mine uses Slingbox and likes it. I've seen it work.
Post Number: 4821
rico thanks but sling box transmit video from tv to computer,
i am looking for opposite way,
Post Number: 881
sada
Slingbox works both ways. Any V/A source from your home can be sent to the web and you can then control your sources and veiw/listen from anywhere that has internet access.
Post Number: 882
Sada,
Nevermind... I see what you are asking now. I must be having a blonde moment.
Username: Hogwart
Warped
Sada, Rico goes both ways so just got a little confused
Username: Joeturn
Post Number: 419
will this work??
http://www.amazon.com/Aitech-Pro-Wireless-Converter-06-078-001-08/dp/B000BD68KM
