Bronze Member Username: BordogoyPost Number: 90 Registered: Feb-08 | dn just went down,. wtf? we just got the new fix yesterday stupid FLANDERS! |
Silver Member Username: Shadow45Mty, Nuevo Leon Mexico Post Number: 307 Registered: Aug-07 | I dont think is down, im still using the LZMA V211 bin and still works, granted takes about 5 min to roll(even with the key roll off) but i get video/sound on all the channels, xcept the P*rn ones. I dont know which box you are using, mine is a c*appy lavasat3200. |
Silver Member Username: RiconissanPost Number: 670 Registered: Feb-09 | Viewsat still up with 090320 bin |
Silver Member Username: PicanhaEast LA Post Number: 383 Registered: Jun-08 | Papi Woods |
Silver Member Username: RiconissanPost Number: 674 Registered: Feb-09 | Esvaldo Chevez F@CK OFF Douche Dick! |
Silver Member Username: Ramiro_gonzoPost Number: 107 Registered: Aug-07 | not down!!!!!!!!!!youre the only thats down... |
Gold Member Username: PlymouthCanada Post Number: 8844 Registered: Jan-08 | dong chad If you have a Pansat, you must put the keys manualy. Here is a good link for get keys update: http://livekeyz.com/ |
Silver Member Username: Desi_mundaPost Number: 231 Registered: Nov-07 | is pansat 2700 working, i mean are we getting some indian or pakistani channel, even 1. please let me know. thanks! |
Bronze Member Username: Dinky_dauPoinciana, Fl Usa Post Number: 26 Registered: Mar-08 | converted flu still up with lzma v211. |
Silver Member Username: LuciaCalgary, AB Post Number: 703 Registered: May-06 | hispanic channels are out! |
Gold Member Username: PlymouthCanada Post Number: 8848 Registered: Jan-08 | Lucia If you talk about Telefonica. Try this keys out today: 1801:007311: 01 : 27 d3 a0 7e 7c 9a b5 5b 28 6e 28 7a c1 ac 6a c0 |
Silver Member Username: Desi_mundaPost Number: 232 Registered: Nov-07 | dinky dau saab or anyone can u tell me what indian or pakistani channel are up on converted flu? please? and also please how to get them step by step, thanks! |
Silver Member Username: Popol_vuhPost Number: 110 Registered: Jan-08 | The latest bins can take quite some time to work when keys change. Be patient, 15 minutes is not uncommon on older machines. As others have said, some channels don't work at all, that's normal. |
Silver Member Username: LuciaCalgary, AB Post Number: 705 Registered: May-06 | whats telefonica? ok i'll try that. And as for channels, im talking about channel 827, 828 and so on in Dishnetwork. |
Gold Member Username: PlymouthCanada Post Number: 8851 Registered: Jan-08 | Lucia #827 up on 110W and #828 are up on 119W Don't put this keys on your receiver. |
Bronze Member Username: RahulusPost Number: 14 Registered: May-08 | I have PANSAT 2800 and how do I put in the keys to my receiver..I haven't had to do it earlier..Please let me know..thnx |
Gold Member Username: DimwittPost Number: 1263 Registered: Aug-06 | Chances are you don't have to enter them now either Let it sit on a channel for 5 - 10 min. or press MENU 1. press Parental Control 2. press Second Pin and enter 0000 3. press NAGRAVISION 2 4. scroll to your desired Provider 5. enter Key Data for Key Number 00 (aka 86) 6. Press OK to Store 7. Scroll up to Key Number field and then right arrow to change to 01 8. enter Key Data for Key Number 01 (aka 96) 9. Press OK to Store 10. Exit out and your done |
